I did this last week at MPIA. The method I used was very similar to
Mark Rivers, but I think I solved his problems with simultaneous
builds. For what its worth, this is the procedure I followed:
1. In CONFIG_SITE, I defined HOST_ARCH to be the the default
architecture I used to compile the IOC files on (in my case
solaris).
2. In CONFIG_SITE.Unix.<arch> for other architectures, I replaced this
with the correct definition. For example, in CONFIG_SITE.Unix.sun4,
I had a line:
HOST_ARCH = sun4
3. Since the home directory of Epics was in a different place on each
machine, I also did the following in CONFIG_SITE.
EPICS_LOGIN = $(shell echo "echo ~epics" | csh -fs)
EPICS_BASE = $(EPICS_LOGIN)/R3.12.0Beta12/base
EPICS_EXTENSIONS = $(EPICS_LOGIN)/R3.12.0Beta12/extensions
All this worked fine, except that `GetVar HOST_ARCH` always returned
solaris. The only place this mattered in the build was in the new version
of blderrSymTbl which did exactly that. I changed it to accept a -h <arch>
parameter and fed the correct one in from the makefile.
I think the ideal is to have a script in base/tools called HostArch
which returns the correct value of HOST_ARCH for the architecture you
are running on. Then, in CONFIG_SITE you define
HOST_ARCH = $(shell HostArch)
and it always works. The following should work (but has not been
checked on all architectures) for the current list of supported
hosts, but it would have to be adapted for new architectures:
#!/bin/sh
# base/bin/tools/HostArch - returns the Epics host architecture suitable
# for assigning to the HOST_ARCH variable
sysname=`uname`
case $sysname in
HP-UX )
echo hp700
OSF1 )
echo alpha
SunOS )
version=`uname -r | sed '1s/^\([0-9]*\).*$/\1/'`
if [ ${version} -ge 5 ]; then
echo solaris
else
echo sun4
fi
echo unsupported
esac
Re: Task Delete of Sequence Crashes IOC Steve Lewis
Re: AO record DOL field fails with a CA link Marty Kraimer
<1995>
2025
2026
Re: Building for more than one host architecture William Lupton
Re: Building for more than one host architecture Nick Rees
<1995>
2025
2026
