1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: More changes.. when does Beta end
To: [email protected], [email protected]
Date: Tue, 20 Jun 95 12:53:09 PDT
This appears to be a NEW bug.  ALS is running production 3.11 code that
works fine that is broken by the Beta DOL bug.  It will have to be twisted
with a work-around to run on this Beta.  We can of course do this - the
real question is how bug-free do we make EPICS releases?  If we do
release I propose that we incorporate a 'known bugs and work-arounds'
into the root directory readme or equivalent.
It might be easier to fix this problem than document it and workarounds.
Are there any other new 'bugs' that require existing programs to be twisted
to work?  I hope there is nothing else like that in the current beta.
Alan K Biocca
> From [email protected]  Tue Jun 20 10:48:58 1995
> Date: Tue, 20 Jun 1995 12:48:06 -0500
> From: [email protected] (Marty Kraimer)
> To the best of my knowledge this bug was in all previous releases.
> In addition there is a simple "work-around". It is as follows
> set up a soft ai record that has INP reference the record in the other ioc.
> Let the DOL field reference the soft ai record. The soft ai record can
> be passive. The dol field can specify PP and MS. This should work.
> Thus I do not think that this bug is sufficient to stop beta13 from becomming
> the official 3.12. If we allow this fix we will be opening the floodgates
> with regards to changes.
> Marty Kraimer
Prev: Re: e2sr name mangling Matthew Needes (LANL)
Next: when does beta end Chris Timossi
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: More changes.. when does Beta end Marty Kraimer
