> > I've encountered a bug while porting EPICS to the Hytec CAMAC controller.
> > The problem is in initDatabase() which is called by iocInit(). The
> > interesting part is how this function ever worked.
> > The problem is in the first call to ellFirst(). If there are no
> > records defined for a specific type, then the field precLoc->preclist
> > is null. However, the call to ellFirst() does not check for this
> > condition and will return a garbage pointer. This works fine with
> > the NI VXI cpu030 card because the data at 0x0 is also 0x0 which causes
> > the for-loop to continue with the next record type. However, with
> > the Hytec card, 0x0 is the start of EPROM which contains non-zero
> > data.
> > Obviously I can easily fix this by checking for a null preclist value
> > but I'm curious how this works on other controllers. I'm also concerned
> > with other areas in the EPICS code which might pass a null ELLLIST value
> > to ellFirst().
> I just looked at the code. A few ststements above the call to ellFirst is
> the statement
> if(!precLoc->preclist) continue
> Thus if no records exist the call to ellFirst will never be made.
> Marty Kraimer
You must have version 3.12. We haven't upgraded yet to that version.
This problem seems fairly pervasive - I've had to add a check in several
places so far, including initialProcess() and buildScanLists(). I get
similar problems running some of the IOC test routines, such as dbl(),
but I haven't yet confirmed that it is related. My guess is that
even 3.12 hasn't fixed all the places where this occurs.
Greg Greene
KineticSystems Corp.
ph: 303-220-7455 x13
fax: 303-220-7458
email: [email protected]
Re: Bug with initDatabase() Marty Kraimer
Re: Quiting MDCT... Marty Kraimer
<1995>
2025
2026
Bug in initDatabase() Patavalis Nikos
<1995>
2025
2026
