1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Bug in initDatabase()
Date: Wed, 12 Jul 1995 00:46:09 +0300 (EET DST)
Greg Greence wrote:
> The problem is in initDatabase() which is called by iocInit()...
> The problem is in the first call to ellFirst().  If there are no
> records defined for a specific type, then the field precLoc->preclist
> is null.  However, the call to ellFirst() does not check for this...
I'm using a rather old EPICS release (R3.12.0Beta1) and the problem
you are reporting has been corrected!
Just after entering the loop that goes for every record type,
and almost before doing anything else (certainly before calling
ellFirst()) there is a check:
    /* For every record type ... */
    for(i=0; i< (precHeader->number); i++) {
       /* Get pointer to location structure for instances of
          record type 'i' */
        if (!(precLoc = precHeader->papRecLoc[i]))continue;
        if (!precLoc->preclist) continue;
I think this solves the problem...
What release are you using?
Nick Patavalis.
([email protected])
University of Athens.
Athens, Jul 12, 1995.
Prev: Bug with initDatabase() greene%denali.UUCP
Next: Re: Bug with initDatabase() Marty Kraimer
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Bug with initDatabase() greene%denali.UUCP
Next: free_gdct - does anyone have a Sun machine I can log into for a few hours?? 415
