1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: arrays in epics records
To: [email protected], [email protected]
Date: Thu, 13 Jul 95 22:12:12 PDT
> Date: Thu, 13 Jul 95 08:09:19 HST
> From: [email protected] (Kevin Tsubota)
> Subject: arrays in epics records
> Can I have array fields and is it also possible to access each individual entry in the array?
Although intended to work with waveform records, the subArray record
might work with your record if you link it to one of the array fields.
Its purpose is to access a sub-array of a full array with specific
offset and length, including the case of a single element.  Details in
Record Reference Manual.  If it doesn't work, you might contact the
author: Carl Lionberger ([email protected]).
	Steve Lewis				[email protected]
	Software Engineering Department		Mail Stop 46A-1123
	Lawrence Berkeley Laboratory		Tel: 510/486-7702
	Berkeley, CA 94720			Fax: 510/486-5936
Prev: arrays in epics records Kevin Tsubota
Next: Re: ezca Jeff Hill
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: arrays in epics records Jeff Hill
