1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Cute error in alh/file.c
To: [email protected]
Date: Fri, 28 Jul 1995 07:50:37 -0500
> char *shortfile(name)
> char *name;
> int len,i;
> char *shortname;
> 	len = strlen(name);
> 	shortname = name;
>     while (len != 0) {
>         if(*(name+len)== '/') {
>             shortname = name+len+1;
>             break;
>         len--;
> Notice that there is no return statement? I can only assume that the compilers
> for Sun and HP have `accidentally' optimized 'char *shortname' into the
> register which is used to return the result. The DECC compiler on the Alpha
> doesn't complain about this construction (do the others?), but the routine
> returns junk which causes a segmentation fault.
I have found that gcc -Wall does a better job of reporting problems than
the sun compiler. It returns the warning:
warning: control reaches end of non-void function
By the way the c rules state:
If no expression appears in the return statement, then no value is returned
from the function; this is always permitted, even if the function has a declared
return type other than void.
C, A Reference Manual, Samuel P. Harbison, etc Third Edition page 234.
The second edition of K&R page 26 has similar words.
This seems like a rather strange rule.
Marty Kraimer
Prev: Announcing ezcaIDL, a new extension Mark Rivers
Next: OMS driver bug? Ian Smith
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Cute error in alh/file.c 415
Next: Announcing ezcaIDL, a new extension Mark Rivers
