1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: ca_pend_event question (VAX/VMS only)
To: [email protected]
Cc: [email protected]
Date: Tue, 8 Aug 1995 10:36:55 -0700 (PDT)
Hello -
In the description of ca_pend_event in the Channel Access Reference Manual,
it says that a very short timeout such as 0.0001 seconds will result in a
"poll".  It appears that on my VAX/VMS system, this "poll" really takes
around 10 milliseconds since the VAX time resolution is only to the
nearest 10 msecs.  Has anybody ever looked into changing ca_pend_event
so that it truly does a poll (at least on the VAX)?
We are using the EZCA routines on the VAX.  When not in a group, the first
thing every EZCA routine does is a ca_pend_event with a 0.00001 sec timeout.
I'm trying to understand why it does a ca_pend_event with a short timeout
instead of a ca_flush_io - can anybody explain?
We have a few applications that do not use EZCA groups (ie, one application
posts many monitors (ezcaSetMonitor) and then periodically gets current
values using non-grouped ezcaGets at different time intervals - ezcaDelay
is periodically called as suggested in the EZCA primer).  I thought
we could stand the overhead of the extra polling, but obviously not with the
10 msec wait.  In this particular application, it's tough to group the
ezcaGet calls.  (OK, Bob Dalesio - you can tell me "I told you so" - go ahead,
make my day!).
-- Stephanie Allison   [email protected]
Prev: [no subject] Matt Bickley
Next: Re: BURT available on Alpha/Unix platform, but a few problems watson
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: ca_pend_event question (VAX/VMS only) Jeff Hill
