1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: BURT modifications
To: [email protected]
Cc: [email protected], [email protected]
Date: Fri, 15 Sep 95 13:08:17 -0400
>I have been given the wonderful task of making some modifications to
>BURT.  One of the things I would like to do while poking around in
>there is remove its use of the C compiler and the C preprocessor.
Depending upon how major your changes are, you might want to consider
how hard it would be to allow BURT to use cdev instead of channel access.
(Goal is to have burt, medm, dm, ar, alh all use cdev).  One prerequisite
to keep that from happening how is to produce a C binding (only C++ now).
One feature in the way of dependencies that CEBAF requires is a feature
that would automatically write to a special record.field prior to
any restore.  We would use that to automatically shut off our injector
gun.  This feature was in the TACL save/restore utility, and is a
requirement for CEBAF (one EPICS currently does not meet).  All other
dependencies I can do without or handle in a script (tcl).  Don't want
to handle this one in a script because of the machine safety issues.
Chip
BURT modifications winans
Prev: BURT modifications winans
Next: Re: Q: NI-1014 GPIB board with Force CPU40. Kazuro FURUKAWA
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RS232 Ian Smith
