1994  <1995>  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <1995>  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Steppermotor Record
To: [email protected], [email protected]
Date: Mon, 2 Oct 95 15:22:41 MDT
  I was working on the steppermotor record a little at CEBAF and
  found a number of problems - most of them related to using the
  IALG field to move to one of the limits on initialization. There
  are also problems with PASSIVE motors with no retry count and
  monitors of the mcw and mccw fields. The fixes are below. Please
  review and put into 3.12.2.
  Also - it should be understood that the OMS motors determine that
  they have finished moving when the position is the same on 3
  subsequent reads (100 milliseconds) - so if the motor is moving
  very slowly - VELO is too small - the readback RBV for the motor will
  not track the desired value VAL.
  if you initialize to a limit - the overshoot will stop the motor
  --- in the source it reads --
  /* stop motor on overshoot */
  if (psm->movn){
  --- should be ----
  if (psm->movn && (psm->init == 1)){
  if you initialize to a limit and the retry count is not 0 ---
  --just after the overshoot check at the same level of indentation
  if(!psm->movn) {
  --should be:
  if(!psm->movn && (psm->init == 1)) {
  if you are using init to a limit in IALG - the move is too big
  status = (*pdest->sm_command)(psm,SM_MOVE,0xfffffff,0);
  ---and
  status = (*pdest->sm_command)(psm,SM_MOVE,-0xfffffff,0);
  ---should be
  status = (*pdest->sm_command)(psm,SM_MOVE,0xffffff,0);
  ---and
  status = (*pdest->sm_command)(psm,SM_MOVE,-0xffffff,0);
  -----(one less f)
  if you are using the fields MCW and MCCW to monitor limits -
  they are not being posted.....
  ---after
  db_post_events(psm,&psm->cw,DBE_VALUE|DBE_LOG);
  ---and
  db_post_events(psm,&psm->ccw,DBE_VALUE|DBE_LOG);
  ---add
  db_post_events(psm,&psm->mcw,DBE_VALUE|DBE_LOG);
  ---and
  db_post_events(psm,&psm->mccw,DBE_VALUE|DBE_LOG);
  --- you also need to put these statements in { ... }
  a passive motor record being set by a slider may not get processed
  again when the final value is put in the record - occurs if the
  record is being processed while new values are being put in the
  record as well.
  --- in the retry portion of the code
  if (psm->rcnt < psm->rtry){
  --- should be
  if ((psm->rcnt < psm->rtry) || (psm->lval != psm->val)){
  	psm->lval = psm->val;
End of returned message
----- End Included Message -----
Prev: Re: mvme162 and epics watson
Next: InterViews for Solaris Rozelle Wright
Index: 1994  <1995>  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS on mvme162 Patavalis Nikos
