I have just finished putting together a small epics data base that uses a
networked terminal server to transmit and receive rs232 data to/from external
devices. I use Andy Foster's (RGO) new multiple output subroutine to call a
library of c routines that perform tcp socket i/o to the server.
My application (Michelle Cryostat Controller) requires that I send occasional
(every few seconds) command strings to various 'droids' (temperature/vacuum
scanners, temperature controller,...) and receive back data. So I don't need
a high spec vme device for the communication. I also save on not using up a
valuable vme slot.
The database can communicate with any of the 32 ports on the server(I'm using
an Emulex) as well as print strings to the parallel printer port on the server.
Potentially there is no limit to the number of servers/ports that can be
connected to with this method, and the server dosn't have to be anywhere near
the ioc, just somewhere (in the world!) on the internet. All that is
required is the server's IP name/number and the port number on the server to
make a connection. The server has to be capable of being set up as a Telnet
Listener.
If anybody would like more details then just let me know.
cheers
Ian A Smith Telephone: +44 (0) 131 668 8257
Royal Observatory Fax: +44 (0) 131 668 1130
Blackford Hill Web: http://www.roe.ac.uk/
Edinburgh
UK
Re: Epics C++ Problems Jim B. Kowalkowski
Re: Epics C++ Problems Jeff Hill
<1995>
2025
2026
What th??? (was: Re: Epics C++ Problems) John R. Winans
XY240 mystery.... Bonnie Montjar
<1995>
2025
2026
