Hello all,
> I have the following problem with the EPICS cadef.h file:
> This gives this warning with the SUN (C++) compiler:
> "./epics.3.12.1/base/include/cadef.h", line 218: Warning (Anachronism): Redefining chid after use in event_handler_args.
> "./epics.3.12.1/base/include/cadef.h", line 218: Note: Type "CC -migration" for more on anachronisms.
> "./epics.3.12.1/base/include/cadef.h", line 257: Warning (Anachronism): Redefining chid after use in exception_handler_args.
> and even worse it is a syntax error! with GNU g++ compiler
> It compiles, when the name is changed. e.g. chid chidname
> Can somebody help me ?!
This problem was also detected by Jim Kowalkowski at APS. A
changed cadef.h supporting the new C++ compilers will show up
in EPICS 3.12.2.
In the short term you can fix the problem by replacing all
instances of the field declaration "chid chid" found within
a structure declaration with "struct channel_in_use *chid".
There are only 3 lines that require changes. Function prototypes
do not require modification.
Note that this is only a problem for folks programming with the
more recent C++ compilers and is not a problem for ANSI/traditional
C programs.
Jeff
______________________________________________________________________
Jeffrey O. Hill Internet [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos, NM 87545 USA FAX 505 665 5107
EPICS RS232 Ian Smith
Re: Epics C++ Problems Jeff Hill
<1995>
2025
2026
Re: Epics C++ Problems Jim B. Kowalkowski
<1995>
2025
2026
