Chris Timossi writes:
> I still dont understand how the epics env. variables are now set
> (when running under MS windows or NT).
> I know I can set them with a script, but is there no longer defaults
> in the source code ?
This problem will show up under VMS also. During the UNIX build
base/src/libCom/O.xxxx/envData.c is created from an ascii
configuration file. This file provides the defaults for the environment
variables. Unfortunately this file is not in with the rest
of the source code. Worse yet it will not exist unless you have
built the source distribution under UNIX. I suppose that we could include
an envData.c template for ms windows and VMS users in the libCom. Has
anyone got a better idea?
Jeff
______________________________________________________________________
Jeffrey O. Hill Internet [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos, NM 87545 USA FAX 505 665 5107
Re: BURT modifications in progress winans
Re: BURT modifications in progress James F. Harrison
<1995>
2025
2026
description Tim Mooney
Re: NT changes for 3.12.2 Andrew Johnson
<1995>
2025
2026
