>The files located within the config/mv167 directory seem to be modified from
>the WRS 5.1 release, not the 5.2 release. The config/all files are modified
>from the 5.2 release.
I can't remember all the details of the 5.2 install at APS... I remember that
the CD from WRS was a nightmare and that installing from it screwed up
ownerships, permissions and the sim-link paths on all the GNU tools. It is
POSSIBLE that the BSP install was messed up somehow as well. However, I
am pretty sure I did it myself and I am pretty anal about those things.
I can not see the references to the config stuff in the 3.12.2 release that you
mention. I suspect they are probably some notes I scrawled out 6 months
ago. With any luck that config tree is in error. Just to make sure, could
you tar up and send me/drop off an official distribution config tree of 5.2?
This way I can see if it matches the one I used for 5.2.
NOTE: If I messed this up somehow, there is probably not going to be any
time for ME to go thru the merge of all that stuff and test it again in 1995.
--John Winans
R3.12.2 vxworks config Bret Goodrich
Re: R3.12.2 vxworks config Jeff Hill
<1995>
2025
2026
<1995>
2025
2026
