1994  <1995>  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <1995>  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: R3.12.2 HP port
To: [email protected]
Cc: [email protected]
Date: Wed, 29 Nov 95 15:07:05 EST
This mail is made of the recycled electrons
Mailer: Elm [revision: 70.85]
R3.12.2 epics source for HP port is now available from
CEBAF ftp site with the password.
To obtain the password,
i) you must be a part of EPICS collaboration or
   you must have an agreement with the collaboration
   (Bob Dalesio [email protected])
ii) e-mail [email protected] a request or
    fax (804)249-7049
iii) call (804)249-7239
> The USER name is XXXXXXX
> The PASSWD is XXXXXXX
> The DIR is XXXXXXX
> Instructions for use:
> Anonymous ftp directions for sublogins			April 1995
> 	Here are some instructions for the anonymous ftp users with sublogins:
> NOTE:  Substitute the username you were given where ever you see USER.
>        Substitute the password you were given where ever you see PASSWD.
>        Substitute the directory you were given where ever you see DIR.
> First FTP to our site.  Type the following
>   $ ftp ftp.cebaf.gov
> Then you will login as anonymous.  Type anonymous at the prompt.
>   Connected to cebafh.cebaf.gov.
>   220 cebafh FTP server (Version 1.7.193.3 Thu Jul 22 18:32:22 GMT 1993) ready.
>   Name (ftp.cebaf.gov:USER): anonymous
> Then you will supply your email address as a password (It is not echoed back).
>   331 Guest login ok, send ident as password.
>   Password: [email protected]
> You are now logged into our site via anonymous ftp
>   230 Guest login ok, access restrictions apply.
>   Remote system type is UNIX.
>   Using binary mode to transfer files.
>   ftp>
> Change to the DIR directory.
>   ftp> cd DIR
>   550 DIR: Permission denied.
> It did not work because user anonymous does not have the correct permissions.
> You must do a sublogin to a user that can access this directory.
> Change to the appropriate user.
>   ftp> user
>   (username) USER
>   331 Password required for USER.
>   Password: PASSWD
>   230 User USER logged in.
> Check your current directory.
>   ftp> pwd
>   257 "DIR" is current directory.
>   ftp>
> This will change your current working directory to the users home directory.
> In your case the users home directory is DIR.  The user will
> always be placed in the DIR directory after executing the user
> command.  They can then use the put or get command successfully.
Johnny Tang     Voice: (804)249-7239  E-Mail: [email protected]
Continous Electron Beam Accelerator Facility
12000 Jefferson Avernue, MS 85A
Newport News, Va 23606
Prev: bug in ca_array_get() when the data type is string Jeff Hill
Next: SOlaris developer's package and 147 BSP Bob Dalesio
Index: 1994  <1995>  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
