Re: C++ performance, employment, and porting issues.
> I would like to raise the question of PERFORMANCE if core code is written
> in C++. While I have no direct experience with C++ performance, I had a
> couple of recent conversations with experienced people that make me worry.
I have compiled the existing pure ANSI C server library using C++ and this
caused no significant change in performance. As with C, C++ programmers who
care about performance will need know what it is that the compiler is doing
for them so that they will know when it is inappropriate to use a particular
feature of the language. Issues related to memory management are likely
to have an impact on performance in a communications application such
as channel access.
> In my experience of applying for jobs with companies
> in the UK, it does not seem to be very widely used.
In the states we see increasing demand for experienced C++ programmers.
> I always thought this was linked to the problem of producing
> portable C++ code.
This is a significant problem. In my opinion there are many dark passages
in this language (C isnt immune here either). It is difficult to create an
ANSI standard for a moving target.
Jeff
All elapsed times below are in fractions of a second.
% catime fred
search test
Elapsed Per Item = 0.001305
channel name=fred, native type=2, native count=1
pend event test
Elapsed Per Item = 0.000170
float test
async put test
Elapsed Per Item = 0.000048
async get test
Elapsed Per Item = 0.000084
synch get test
Elapsed Per Item = 0.003738
string test
async put test
Elapsed Per Item = 0.000152
async get test
Elapsed Per Item = 0.000174
synch get test
Elapsed Per Item = 0.003986
integer test
async put test
Elapsed Per Item = 0.000043
async get test
Elapsed Per Item = 0.000079
synch get test
Elapsed Per Item = 0.003674
free test
Elapsed Per Item = 0.000015
______________________________________________________________________
Jeffrey O. Hill Internet [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos, NM 87545 USA FAX 505 665 5107
- Re: A C++ API for the pcas watson
ATTN Platform Developers Marty Kraimer
Re: GDCT/freeGDCT under solaris 415
<1995>
2025
2026
Re: A C++ API for the pcas Michael A. Oothoudt
<1995>
2025
2026
