Rozelle writes:-
>Hi Greg,
>I built freegdct under Solaris. The Makefile.start that is currently being distributed needs
>to be changed to
> @case "$(HOST_ARCH)" in \
> sun4|solaris) \
>instead of just sun4. And you have to have a decent copy of interviews.
>I got mine from Jim Kowalski at Argonne. He had modified it
>so that it worked with Solaris.
Note that the Alpha/Unix version of interviews from interviews.stanford.edu
is badly broken. In fact, it doesn't seem to work at all. I fixed the problems
with Interviews, essentially from scratch, at least as far as providing
sufficient functionality to get free_gdct working.
For those porting to other architectures (esp. 64 bit ones), look out for
the usual confusion between `int's and `long's. A wonderful `gotcha' in
C++ is that class definitions like this:-
class rubbish : public otherRubbish {
void someFunction( int, ....);
do not reveal the important fact that 'someFunction' may be declared to be
virtual in a superclass. Hence, simply changing `int' to `long' completely
changes the operation of the program - silently, since C++ compilers see
these routines as completely different & most don't bother to inform you that
'someFunction' is masking a virtual function further up the class hierarchy.
InterViews is full of stuff like that. If anyone wants the (pseudo)working
Alpha/Unix Interviews, I'll be glad to provide...
Tony
Dr Anthony D Cox
Computer Systems Specialist
Stanford Synchrotron Radiation Laboratory
Stanford Linear Accelerator Center
MS 69, Box 4349
Stanford CA 94305
[email protected]
Re: A C++ API for the pcas Jeff Hill
Re: building vxWorks for nitro-260 Bill Brown
<1995>
2025
2026
Re: GDCT/freeGDCT under solaris Rozelle Wright
Replacing default.dctsdr with all ascii files Marty Kraimer
<1995>
2025
2026
