1994  <1995>  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <1995>  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: building vxWorks for nitro-260
To: [email protected], [email protected]
Date: Fri, 8 Dec 95 11:34:44 PST
FYI, here's the reply from Heurikon.
> From [email protected] Thu Dec  7 11:11:16 1995
> From: "David Greene" <[email protected]>
> Date: Thu, 7 Dec 1995 13:10:25 -0600
> In-Reply-To: [email protected] (Bill Brown)
>         "Re: (Fwd) Re: VxWorks Tapes" (Dec  5, 12:30pm)
> Bill,
> Following is a suggested workaround, but first is a general suggestion.
> IN GENERAL:
> Normally, for a specific target, it is best to define options in the config.h
> file.  The settings in this configuration header file supercede anything set in
> configAll.h.  The "Programmer's Guide: VxWorks 5.2" explains this very well in
> sections 10.3.1.1 and 10.3.1.2 (and mercifiully with less than a page of text).
> WORKAROUND:
> Here is the workaround I suggested to the other customer who is seeing
> apparently the same problem:
> 	-Put all desired option definitions into config.h instead of
> configAll.h
> 	-INCLUDE_SECURITY may cause compile problems when defined in config.h,
> 	 so I put it in configAll.h
> This made the problem go away.  I don't yet know why and am still investigating
> the root cause.
> Dave
It works, altho I haven't a clue as to why.  One can go on for days about the
wisdom of invoking which things in what .h files.  I thought that our setup
was a fairly generic release from WRS, but since I didn't originally build
it (or install the release) I could be wrong.
In anycase, if anyone else wants to use these boards, it would be a good
idea to squirel this info away in a "safe place.
I'm impressed with the support I got from Heurikon on this.
-bill
Prev: Re: GDCT/freeGDCT under solaris 415
Next: Re: A C++ API for the pcas 415
Index: 1994  <1995>  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: building vxWorks for nitro-260 John R. Winans
Next: A possible alignment fix side-effect. Peregrine McGehee
