1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: A possible alignment fix side-effect.
To: [email protected]
Date: Tue, 5 Dec 1995 16:31:16 -1000
We have been successfully running EPICS R3.12.1 on Sun Sparc 1e and
Force Sparc 5 based IOCs for the last few months and last week
encountered the following sequencer behavior:
At a period of several seconds to several minutes the Sequencer
Auxillary Task crashes with a memory alignment error. Also the vxWorks
routine memShow(1) forces a crash as well.
The root cause of this was found to be:
If the sequencer application accessed any non-local process variables
(i.e. actually used Channel Access) then the stack size on "seqAux"
would overflow the 2000 byte size defined in seq_main.c.
I suspect that this is due to the message buffers being padded out to
comply with 8-byte alignment.
I haven't identified the specific section of code within channel access
that seems to be responsible for this growth of the stack but the
difference between using CA and using only DB access shows up in the CA
routine cac_select_io(). [technical note: iiuList.node.next is always
NULL if no CA (UDP or TCP) related file descriptors need to be checked].
So - the stats on the seqAux stack for the sparc port are:
CUR: 736	HIGH: 2848
The high-water-mark grows during the first few minutes and then seems
to be stable.
Note: the _seqAuxTask runs at one priority level above the actual
sequencer app - and it's _only_ function is to call
ca_pend_event(10.0) forever. Why is that?
Aloha,
	Peregrine
Peregrine M. McGehee			Canada-France-Hawaii Telescope
Telescope Control Systems Group		P.O. Box 1597, Kamuela, Hawaii
Prev: Re: building vxWorks for nitro-260 John R. Winans
Next: Re: A possible alignment fix side-effect. Andy Kozubal
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: building vxWorks for nitro-260 Bill Brown
