1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ATTN Platform Developers
To: [email protected]
Date: Wed, 13 Dec 1995 09:23:35 -0600
>        Again, it would convenient to have pointers in one place, and
>        you could have pointers to your local copies as well as to the
>        standard master sites.  That way APS is not responsible for
>        having the very latest version.  I would keep only the original
>        xxx.tar.Z.
I agree that this should be our minimum offering.  However, as someone who has
spent a great deal of time messing around with things gotten from 'the net'
I must say that it is a REALLY annoying thing to have to figure out what
versions do and don't work with some version of another tool.  Then it gets
worse if the one that I NEED is too old to be found at the expected site.
(Perl's @-syntax change comes to mind... in that case, using the latest
version was not what if you want to run dusty-deck code.)
I would like to see the EPICS distributions explicitly state what versions
of net-sourced things it was built and/or tested with.  I would also like
to see those tool versions made available at the EPICS distribution sites (if
reasonable and/or possible.)  This should make it easier for the new guys that
might not know the first thing about some abscure thing that they may not know
exists, how to build or even care about.
This is already done for the lex and yacc that we use in EPICS (although
these are such an integral part of the epics core that we include them in
base.)
--John Winans
Re: ATTN Platform Developers watson
Prev: Re: ATTN Platform Developers Steve Lewis
Next: Re: ATTN Platform Developers Dr. Pete Jemian
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: ATTN Platform Developers watson
