I have started looking at Marty's new ascii database software and, on
the whole, I like it a lot. However, I don't like the path construct -
it seems restrictive and, in particular, it depends on the ascii files
staying in the same relationship in the directory structure to work. If
I move my code around I don't want to have to edit it to get it to
work.
At a bare minimum I suggest that dbAsciiExpand take at least one
option, -I <path>, and its behaviour be identical to that of the C
precompiler. (If you hadn't used # as a comment character I would have
suggested using the precompiler itself). Like for the precompiler, the
-I option should be able to be repeated a number of times to build up a
list of search paths.
This will allow application environments to build a database
construction rule similar to normal compilation rules for C include
files. (This is something we know how to do and know works...)
I have had a brief look at the code and I feel that it can't be that
difficult to do, but of course Marty might enlighten me on this :-).
Comments anyone?
Nick Rees
Joint Astronomy Centre Ph: +1 (808) 961-3756
660 N. Aohoku Place Fax: +1 (808) 961-6516
Hilo, HI. 96720 Internet: [email protected]
Re: Returned mail: Cannot send message for 3 days Steve Lewis
Re: Hardware Supported by EPICS Tim Mooney
<1995>
2025
2026
Sun Sparcstation model numbers Tony Carter, MIT Bates Linac
<1995>
2025
2026
