Nick Rees suggested that the path for the ascii database files should
be just like the UNIX path, i.e. a list of colon separated directories.
After thinking about it, I agree completely. I dont know what I was
thinking. Here is the way path will be handled:
NEW METHOD FOR PATH
The path will follow the normal Unix conventions, i.e. it will be of
the form:
directory:directory: ... :directory
The static database access library will provide the following
routines
dbPath(pdbbase,"<path")
dbAddPath(pdbbase,"<path>")
The following commands can be given in definition files
path "path"
addpath "path"
dbExpandInclude will have the format
dbExpandInclude -I "path" file1 ...
The ioc routine dbLoadDatabase will have the format:
dbLoadDatabase("file.db","path")
dbExpandInclude and dbLoadDatabase determine the default path as follows:
If the path argument is not NULL it is the default
else if the env variable EPICS_DB_INCLUDE_PATH is defined it is used
else the default path is ".", i.e. the current directory.
END MESSAGE FOR PATH
Note also that, per Jeff Hills suggestion, all references to ascii are being
removed. I hope to have a new beta release and greatly revised Application
Developer's Guide ready in about 2 weeks.
Marty Kraimer
default drvSup.ascii Jeff Hill
Re: CA internal failure Jeff Hill
<1996>
2025
2026
Re: Ascii databases Nick Rees
Returned mail: Cannot send message for 1 hour Marty Kraimer
<1996>
2025
2026
