1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Ascii databases
To: [email protected]
Date: Wed, 10 Jan 96 08:35:58 HST
> This happens EVERY time file is opened. The >= 2 second overhead
> probable comes for establishing the ftp connection,
Yes, I am aware of this - I didn't mention it but I probably should
have said that I feel the only realistic solution to the ftp problem
(whatever path mechanism you have) is to use dbAsciiExpand.  Having
accepted this, any worry about efficiencies in path mechanisms
disappears.
Having said this, I am also leaning towards having UAE encourage users
to create an ascii equivalent of default.dctsdr (i.e. by default
expanding all.ascii) no matter whether they use nfs or ftp, and using
the expanded file wherever default.dctsdr has been used in the past.
(e.g. the expanded file would be used by medm and Capfast and loaded
separately on vxWorks). This would avoid unexpected efficiency problems
and is very similar to current working practices so would probably be
accepted easily. After all record, device and driver support get
changed far less frequently than the record definitions so why do all
those rebuilds?
Nick
Prev: Re: Ascii databases Marty Kraimer
Next: Single seat WRS licenses Bob Dalesio
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Ascii databases Marty Kraimer
