I need time to read and think about all of Nick's comments so the following
is just to clarify the problem about many includes taking a long time on
vxWorks if NFX is not used..
> > Another goal was quick loading of ascii files. Thus the path mechanism is
> > not as general as that supported by the c preprocessor, i.e. the rules
> > always determine a unique place to locate an include file. The rules
> > work very well on Unix (less than 1 second to load all menus, record types,
> > devices, and drivers supplied with base). On vxWorks if NFS is used
performance
> > is still acceptable. If NFS is not used then there is about a 2 second
> > overhead for every file opened. This is not acceptable (> 2 minutes to
load).
> > This is the only reason for dbExpandAscii.
> Yes, but these times would be about the same if you had a search path
> mechanism since I believe all the files in base are actually in one
> directory which, (if you were sensible) would be the first in the path.
The problem can not be solved by an efficient search path.
The problem is that if NFS is not used vxWorks uses ftp.
Every time a file is opened vxWorks does the following:
1) Create ftp connection
2) Read entire file into memory
This happens EVERY time file is opened. The >= 2 second overhead
probable comes for establishing the ftp connection,
Marty
Re: Ascii databases Nick Rees
<1996>
2025
2026
<1996>
2025
2026
