1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Doc: Link Field Syntax
To: [email protected]
Date: Thu, 18 Jan 1996 10:37:56 -0600
> From [email protected] Thu Jan 18 10:00 CST 1996
> From: Andrew Johnson <[email protected]>
> To: Marty Kraimer <[email protected]>
> Cc: [email protected]
> Date: Thu, 18 Jan 1996 15:57:07 +0000 (GMT)
> Priority: NORMAL
> X-Mailer: Simeon for Windows
> X-Authentication: none
> Mime-Version: 1.0
> Content-Type: TEXT/PLAIN; CHARSET=US-ASCII
> Content-Length: 1706
> Marty,
> Can I make a suggestion about hardware addressing for a future ascii database
> release, resulting from my having written a number of drivers in recent months?
> I found the standard address types available to be somewhat restricting, so for
> more than one driver I ended up using INST_IO to provides a string which I could
> then parse for myself in the device or driver layer.  What would be really good
> would be a way of allowing the device layer to define what format a hardware
> address should take, rather than providing a fixed number of formats as at
> present.
> Obviously existing device support doesn't expect this, so it would probably be
> necessary to provide the current formats to existing drivers somehow without
> having to change them.  I haven't really thought about how you might specify the
> address format, but it is something which I think could be incorporated into the
> (very worthwhile IMHO) work you're doing.
This is an area where we know EPICS is deficient. We have had a LOT of discussion
about this topic. epicsRX was a failed attempt to, amoung other things,
solve this problem. We have not been able to agree on a good solution.
I do think we should, in the future, make another attempt.
Marty Kraimer
Prev: Re: Doc: Link Field Syntax Andrew Johnson
Next: ATTN Base Developers - base/include Marty Kraimer
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
