1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: ATTN Base Developers - base/include
To: [email protected]
Date: Fri, 19 Jan 1996 09:42:46 -0600
The following changes will be made to the base directory structure:
1) All files in base/include will be moved to directorys under base/src.
   During build public .h files will be installed into base/include
2) base/rec will disappear. The generated h files will be installed in
   base/include and the database definition files (.db) into base/db
The base/include should NOT contain CVS controlled files.
These files should reside in a base/src/xxx directory and installed
into base/include. In addition the header files for menu and record
definitions should also be installed in base/include. The ascii
database definition files (.db) should be installed into base/db.
Unless someone expresses strong opposition Janet and I will do the following
next Monday:
1) Create a new directory base/src/include
2) Copy all files currently in base/include to base/src/include
3) Perform a "cvs rm" on all the .h files in base/include
4) Make an initial stab at moving as many files as possible from
   base/src/include to the base/src/xxx directories where they belong.
5) Perform a cvs add on each include file that was moved.
6) Make everything build and install all necessary .h files into base/include
When we are done only a few files should remain in base/src/include. We can
decide later what to do about them.
If any base developer has made modifications to files in base/include
in the master EPICS tree at APS you may want to perform a cvs commit.
Before making the changes listed above we will perform a cvs update
on everything in base and config.
Marty Kraimer
Prev: Re: Doc: Link Field Syntax Marty Kraimer
Next: symbols for scan, dfanout, and seq records Sarah Quady
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
