Hi guys:
If you have the time could you answer a question?
Why would the following code fragment not work?
double waveform_array[16384];
assign waveform_array to "WAVEFORM_ARRAY.VAL";
/****** Acquire data and stuff it into an array: this part *****/
/****** works because I can print out believable data using *****/
/****** the printf statement below. *****/
/* write to waveform */
%% array1_ptr=lpanarray1;
%% for(count=0;count<lnumsamples;count++)
%% waveform_array[count] = (double)(array1_ptr[count]*3.091e-10);
%% printf("%e\n",waveform_array[count]);
pvPut(waveform_array);
My database file for this record looks like this:
record(waveform, "WAVEFORM_ARRAY")
field(DESC, "Array for HP positions")
field(SCAN, "Passive")
field(PINI, "NO")
field(PHAS, "0")
field(EVNT, "0")
field(DTYP, "Soft Channel")
field(DISV, "1")
field(SDIS, "0")
field(DISS, "NO_ALARM")
field(PRIO, "LOW")
field(FLNK, "0")
field(RARM, "0")
field(PREC, "4")
field(INP, "0")
field(EGU, "nm")
field(HOPR, "1.0e-08")
field(LOPR, "-1.0e-08")
field(NELM, "16384")
field(FTVL, "DOUBLE")
field(SIOL, "0")
field(SIML, "0")
field(SIMS, "NO_ALARM")
Instead of putting this array into my waveform record, the dang computer
prints the error message:
error from CA on WAVEFORM_ARRAY.VAL
The array or data structure specified will not fit in CA message buffer
Any ideas what's wrong? Thank you very much!
John Spring
Re: request to modify db_name_to_addr for USHORT mapping Marty Kraimer
EPICS Master Tree Developers Marty Kraimer
<1996>
2025
2026
Re: Displaying waveforms Marty Kraimer
<1996>
2025
2026
