1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Displaying waveforms
To: [email protected]
Date: Fri, 26 Jan 1996 08:06:27 -0600
> From [email protected] Fri Jan 26 03:52 CST 1996
> Date: Fri, 26 Jan 96 01:51:27 PST
> From: [email protected] (John Spring)
> Subject: Displaying waveforms
> Content-Type: text
> Content-Length: 1636
> Hi guys:
> If you have the time could you answer a question?
> Why would the following code fragment not work?
> double waveform_array[16384];
> assign waveform_array to "WAVEFORM_ARRAY.VAL";
> Instead of putting this array into my waveform record, the dang computer
> prints the error message:
> error from CA on WAVEFORM_ARRAY.VAL
> The array or data structure specified will not fit in CA message buffer
> Any ideas what's wrong? Thank you very much!
> John Spring
At the present time Channel Access can only transmit messages that fit
in it's tcp buffer which is declared to be 16K Bytes.
Marty Kraimer
Prev: EPICS Master Tree Developers Marty Kraimer
Next: Re: module_types.c Marty Kraimer
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Displaying waveforms John Spring
Next: Re: Displaying waveforms Jeff Hill
