Steve,
> Between R3.12 and 3.12.2, iocLogDisable in iocLogClient.c got
> changed to LOCAL, that is, static. Thus, setting
> iocLogDisable = 1
> at the VxWorks command line no longer disables logging. (In fact,
> you are reminded that you have created a new symbol.)
> I assume this was inadvertently done when setting most of the other
> global variables to LOCAL in that module.
> If the intent was *NOT* to change the behavior, this should be corrected
> on line 67, iocLogClient.c, in base/src/libvxWorks:
> LOCAL int iocLogDisable = 0;
You are correct that this was inadvertently done when setting most
of the other variables to LOCAL. I suspect that this change will not cause
significant grief given the accompanying improvements made to the
log client:
o it no longer blocks iocInit() if the log server isnt available
even if iocLogDisable is FALSE
o the log client also now periodically attempts to reconnect to the
log server if it is restarted
This is fixed here at LANL (but not yet committed to CVS at APS).
Jeff
______________________________________________________________________
Jeffrey O. Hill Internet [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos, NM 87545 USA FAX 505 665 5107
distant rs232 Ian Smith
EPICS archive to DADiSP format? Leroy Rodriguez
<1996>
2025
2026
iocLogDisable Steve Lewis
<1996>
2025
2026
