More about macro substitution:
Nicks writes:
>FROM [email protected] Mon Feb 12 14:02 CST 1996
>1. I don't think the current syntax precludes the ommission of a
> reserved word such as `set' or `define' - just an embedded equals sign
> may be sufficient. Then the amount you type must be about the same.
>2. I believe the current dbLoadTemplate is really just a host side tool
> since it writes to stdout. Am I correct? Thus you don't really have to
> worry about the number of file opens if you are just wanting to provide
> the same functionality. Basically, I thought the conclusion was that if
> you have many files and use ftp you would always use dbAsciiExpand on
> the host for efficiency reasons.
I disagree, dbLoadTemplate() is useful running on the IOC.
>3. dbLoadAscii could always buffer its file handles... (No, I don't think
> I like this either - it isn't really realistic if you are using ftp on
> VxWorks).
This seems very bad.
>4. I agree to supporting both formats. However, I think the syntax that is
> chosen should be consistent, and the semantics such that:
>file gizmo_database.db
> i1{ pre=part1,parm=big, alarm_limit=20 }
> i2{ pre=part2,parm=medium,alarm_limit=30 }
>is identical to (changing my syntax to match yours):
>pre=part1
>parm=big
>alarm_limit=20
>include "gizmo_database.db"
>pre=part2
>parm=medium
>alarm_limit=30
>i.e. the `file' statement is sort of an implied for loop.
> Now the user needs to maintain 300 files. Tell me if there is something
> I am misunderstanding.
>No, I think you had it absolutely right.
I do not like this at all. Remember, we have many users already set up
to use the other format. I think it is unreasonable to ask them to
change to a format that increases the maintainence of their files and
possibly reduces readability of substitution variables.
Jim
Re: PACT -> SDIS Marty Kraimer
Re: PACT -> SDIS Ian Smith
<1996>
2025
2026
Re: macro substitution William Lupton
<1996>
2025
2026
