thanks for the reply:
On Tue, 13 Feb 1996, Marty Kraimer wrote:
> > 1: I can't monitor the PACT leg with either probe or cau etc, nothing can
> > connect to it, so it is impossible to verify its operation.
> I think that what you mean is that db_post_event is not called for
> this field. It is possible to look at PACT with cau, probe, etc.
> The problem is that monitors are never triggered.
I couldn't get probe to connect. In an attempt to put a copy of the error
message here I tried just now to connect with probe, and today it did
connect(??). So yes you can use probe etc to connect to the PACT field,
but as you point out you won't see any change in value.
> I would image that what you want is to detect records that are stuck,
> i.e.PACT is true forever.
In my particular case I'm doing something else; if you imagine a pipeline
of records with the first one activating every 10 secs and the rest
passive but with FLNK daisey chained. Just occasionally a subroutine record
half way down takes longer to process than 10 seconds, so its PACT field is
used to stop the first record starting up again until the pipeline has
completed.
No doubt a call back solution could implemented, but I thought it easier
to use the PACT and SDIS fields. It does work, I just couldn't prove it!
> > 2: If the record is actively processing, say every 10 seconds, then it
> > seems to count the number of times it should have activated whilst it is
> > disabled and then, when it is re-enabled, it seems to process n
> > times without a 10 second wait between each. Ie, if it was disabled for 60
> > seconds then when it is re-enabled, it processes at least twice, perhaps
> > 6 times, instantaneously. The record behaves itself if it is passive.
>This is called "Cached Puts"
Yes, that fits, the records process so fast (compaired with us humans)
that it was difficult to tell if it was 6 times or twice.
I'm not sure what to suggest for the dillema this has exposed, but thanks
for confirming the behaviour of the database.
cheers
Ian A Smith Telephone: +44 (0) 131 668 8257
Royal Observatory Fax: +44 (0) 131 668 1130
Blackford Hill Web: http://www.roe.ac.uk/
Edinburgh
EH9 3HJ
UK
- Re: PACT -> SDIS Marty Kraimer
Re: macro substitution Jim B. Kowalkowski
<1996>
2025
2026
<1996>
2025
2026
