1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Burt and km under Solaris
To: [email protected]
Date: Fri, 16 Feb 1996 21:03:38 +0000 (GMT)
On Fri, 16 Feb 1996 12:50:42 -0600 "John R. Winans" <[email protected]> wrote:
>Sorry, your CPP is too smart for BURT.  You might be able to get an older or
>different one working by putting a different one in your path when running
>BURT.
Probably too dumb actually - this makes sense under Solaris where /usr/ucb/cc
aborts with exit status 1, because the compiler isn't bundled.  I provided
binaries to J.F. Gournay, so he probably doesn't have SUNWspro.  However, the CPP
in /usr/ccs/lib should work, so the simple answer is probably to create a symbolic
link to it named cc in some BURT-searched directory (will this work?).
>>	Another point : burtrb and burtwb needs to link libXt.so.5.0  and
>>libX11.so.5.0 at startup. Why ? Moreover, Solaris 2.5 is delivered with
>>libXt.so.4.0  and libX11.so.4.0 .
>I have no idea why this is so... It makes no sense to me.
It does if you realise that the binaries he is using were copied from APS's
/usr/local/epics/extensions/bin/solaris directory, where they were compiled
against X11R5 rather than openwin.  I can't build BURT here because it won't
compile using g++.
Anyone fancy making a set of BURT binaries available which were compiled against
openwin instead?  We don't need them, but I'm happy to keep them in my ftp area
with the other Solaris binaries, ftp://ftp.ast.cam.ac.uk/pub/epics/extensions
- Andrew
  O o ._    Andrew Johnson, Royal Greenwich Observatory
     __\\_      Madingley Road, Cambridge, CB3 0EZ
  __|ooooo|__   Tel +44 (0)1223 374823  Fax 374700
~~\_________/~~	WWW http://www.ast.cam.ac.uk/~anj/
Re: Burt and km under Solaris John R. Winans
Prev: Re: Burt and km under Solaris Jeff Hill
Next: Field type Andy Kozubal
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Burt and km under Solaris John R. Winans
