We are using AR to store a large number of waveforms. The database records define
the array type (FTVL) as either USHORT or UCHAR. However, AR converts these to
type `float' on output to the archive files. This conversion uses much more disk
space than we would like. Is there a way to force the output type to be `unsigned
short' or `unsigned char' (or even `short' or `char')?
IDL/pvwave has a similar problem. The caget() function converts USHORT to type `float' .
We can handle this with something like x = fix (caget('c1071its')), but this seems
like an inefficient way to handle the problem.
On a related subject--I noticed that db_access.h and dbFldTypes.h (in base/include)
define the "DBF_" types differently. After browsing through the base and extensions
source code, I found some code includes db_access.h whereas some code includes
dbAccess.h, which in turn includes dbFldTypes.h. Which is correct?
| Andy Kozubal (DX-7) | E-mail: [email protected] |
| Mail Stop P942 | |
| Los Alamos National Laboratory | Phone: (505) 667-6508 |
| Los Alamos, New Mexico 87545 | |
Re: Burt and km under Solaris Andrew Johnson
Re: Burt and km under Solaris John R. Winans
<1996>
2025
2026
Re: Burt and km under Solaris J.F. Gournay
Re: Field type Jeff Hill
<1996>
2025
2026
