BURT
burtrb now works correctly.
I had a minimal environment to run my EPICS applications ... which missed to
define the cc compiler. As John Winans suggested, I put the SUNWspro cc compiler
in my path and now everything is ok.
I tried also this :
> If you are not using any macros (ya know #defines) in your BURT files, you
> could probably make a shell file named 'cc' in your path when running BURT
> that simply contains "cat -;exit 0".
I had the following result :
--- Start processing files
file >/home/sigx0/sig/ttf/burt/injector/inj1.req<
preprocessing ... done
ERROR: BurtProcessRequestFile() encountered invalid pvar name in line ><
**** END BURT LOGFILE
Anyway, my problem is solved as we have access to the right c compiler.
I have always the message
"did not find any read only notify values ... NO OUTPUT FILE CREATED"
in the burtwb logfile but the restore is ok.
KM
I tried to transfer km.gz from ftp.aps.anl.gov several times monday and this
morning without any success. I had a terrific 50 bytes/second transfer rate and
my ftp tool seems to be cute enough to cut the transfer after 15 minutes seeing
that the task is impossible !!!
Any suggestions to boost the link ?
Many thanks for the help
Jean-Francois Gournay
CEA Saclay
Re: macro substitution William Lupton
description for archive record Matthias Clausen DESY -MKV2/KRYK-
<1996>
2025
2026
Re: Burt and km under Solaris John R. Winans
Field type Andy Kozubal
<1996>
2025
2026
