Andy writes:
> Another requirement of the Gemini Project is to be
> able to dynamically change access to various records and
> fields. If my understanding is correct, you can do this by
> calling a special routine from a SUB record which re-initialises
> access security by re-reading the ACF.
> What would happen, under these circumstances, to a "dm" display?
> This change in access security could well mean that
> controllers which previously only had read permission now
> have write permission as well.
> Could "dm" be made to update dynamically? My feeling is that
> it could, if it were only displaying simple text like "Access denied"
> and didn't require redrawing of boxes with different colours.
> Andy
Dm is currently set up to get changes in access using a
CA callback that gets executed when access changes, so it
will be able to dynamically reflect the change. Currently
it just ignores the information. I hadn't anticipated
changes to access being really frequent, so I hadn't viewed
it as real performance issue. I was planning to move from
"access" appearance to "no-access" appearance, etc. dynamically.
This could be fairly ugly if access will be changed really
rapidly. Anyone planning to change back and forth faster
than once a second or so?? (Even that rate could drive the
viewer nuts!)
The change is easiest for controllers that move between
read/no write and read/write, since they're already basically
visible in a normal state. Changing between no read and read
would be the biggest hit.
BTW, thanks to all for the input. I'll mull it over and try
to write up a strawman.
Deb
Deb Kerstiens [email protected]
Phone (505)667-3396
LANL AOT-8,MSH820 PO Box 1663, Los Alamos, NM. 87545
Re: EPICS Access Security 415
Re: EPICS Access Security Jeff Hill
<1996>
2025
2026
"dm" and Access Security Andy Foster
Re: "dm" and Access Security Jeff Hill
<1996>
2025
2026
