Gabor Csuka wrote:
> Hi,
> In EpiX R3.12.2 (+ DESY update) I have founded:
> H1_1 efaea0 0
> task: 0Xce682c callback
> Illegal Lock Set Lock Set out of range:dbScanLock
> task: 0Xcf7f4c taskwd
> task ce682c callback suspended
> Any idea ?
> Regards:
> Gabor Csuka
> DESY, Germany
One of two things probably happened.
1) iocInit did not complete. Check this first by carefully looking at
messages displayed on vxWorks console while iocInit is executing.
2) Something wrote to illegal part of memory including the LSET
field of a record. This happens for one of two reasons:
a) Bad record/device support. Common problem when developing new
b) The record/device support was compiled against a different version
of epics than default.dctsdr. This happens if fields in record
are changed between epics versions. Perform a gnumake clean
and then rebuild local record/device/driver support.
If you dont have quick success try removing all record instances that
use locally written record/device/driver support and slowly add it
back until problem can be isolated to particular record/device support.
Marty Kraimer
- Illegal Lock Set Lock Set out of range:dbScanLock Gabor Csuka
vxWorks stat through EPICS records Jim B. Kowalkowski
<1996>
2025
2026
<1996>
2025
2026
