1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: vxWorks stat through EPICS records
To: [email protected]
Date: Tue, 12 Mar 1996 11:01:24 -0600
Everyone,
I've put together ai/ao device support that efficiently gives access to the
following vxWorks statistics:
    ai:
        free_bytes       - number of bytes in IOC not allocated
        allocated_bytes  - number of bytes allocated
        load             - estimated percent CPU usage by tasks
        tcp_connections  - number of TCP connection currently in use
    ao:
        memoryScanRate   - max rate at which new memory stats can be read
        tcpScanRate      - max rate at which TCP connections can be calculated
        loadScanRate     - max rate at which load can be calulated
        loadSampleRate   - vxWorks spy facility samples-per-second for load
        loadSampleLength - length of time in second that samples for load
                           calculation are taken.
Get the source code from the APS ftp server:
	epics.aps.anl.gov:pub/epics/extensions/devAiStats.c
A sample database and doc are included as a comment in the source code
along with the devSup.ascii modifications needed.
Jim
Prev: Re: Illegal Lock Set Lock Set out of range:dbScanLock Marty Kraimer
Next: Channel access security Frank Lenkszus
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
