Mark Rivers wrote:
> Folks,
> I just wanted to follow up on Jeff Hill's post regarding my observations on
> the time required for ca_pend_event().
> There is an error in the R3.12 Channel Access Reference Manual. In the
> comments under the description of ca_pend_event() it says that:
> "A very short TIMEOUT such as .0001 seconds will result in a poll
> (i.e. channel access will just check for file descriptor activity and
> then return)."
> This is incorrect. In fact the threshold is 1 microsecond. Only TIMEOUT
> values below 1 microsecond result in a poll. TIMEOUTs of 2 microseconds will
> often delay ca_pend_event by 1 tick of the system clock. Measured values of
> the time required for ca_pend_event(2.e-6) are 10 milliseconds on Sun4 and
> SGI, 1 msec on Alpha, <.4 msec on Solaris.
> Jeff has suggested 2 solutions to the problem (in addition to fixing the
> documentation):
> - Setting the threshold to (1.0/CLOCKS_PER_SEC). Since CLOCKS_PER_SEC is ansi
> this would be portable. Note that, for example, this would result in any
> TIMEOUT less than 10 msec on a Sun4 result in a poll.
I have made this change however ansi CLOCKS_PER_SEC is 1000000
under sunos4 - therefore the threshold will still be 1uS.
Under vxWorks CLOCKS_PER_SEC is set to sysClockRateGet() and this typically has a value
of 60 - and therefore the threshold will be about 17 mS.
> - Making the TIMEOUT value which will result in a poll a symbolic constant.
> Note that the value of SELECT_POLL, defined in iocinf.h cannot be used,
> since it is defined as 25 msec.
instead I have added a new call - ca_poll() - which will be a macro that
calls ca_pend_event() with a delay short enough to guarantee a poll
Jeff
______________________________________________________________________
Jeffrey O. Hill Internet [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos, NM 87545 USA FAX 505 665 5107
- ca_pend_event() Mark Rivers
Device support for MKS vacuum gauges? Mark Rivers
Allen Bradley DCM Bret Goodrich
<1996>
2025
2026
<1996>
2025
2026
