> From [email protected] Fri Mar 29 10:50:35 1996
> Return-Path: <[email protected]>
> Date: Fri, 29 Mar 1996 17:48:19 +0000 (GMT)
> X-Sender: ajf@orc
> To: Epics Questions <[email protected]>
> Subject: CALC record question
> Mime-Version: 1.0
> Content-Type> : > TEXT/PLAIN> ; > charset=US-ASCII>
> Content-Length: 1361
> X-Lines: 39
> Can anyone help me with the following:
> I am trying to reset a value used in a calculation record
> from a button on a 'dm' screen. The CALC field is set to
> A+1 and the VAL field is looped back to INPA, so that continual
> processing of the calculation record gives: 1, 2, 3, 4, etc.
> I want a button on a 'dm' screen such that when it is pressed, the
> above calculation starts again at 0. I thought this should be easy
> but haven't managed it yet.
> I tried letting the button press put the
> value 0 into INPB and changing CALC to B*{A+1} so that,
> normally B=1 and we have as before. When the button is
> pressed, the record processes once with B=0 and then the
> whole thing starts again.
> This doesn't work.
> I suppose because the above means that INPB needs to take two
> inputs (the first, a hardwired 1, the second a 0 put into B when
> the button is pressed).
> In this case, how can the calculation record know which value it is
> supposed to be using? Or am I going about this in totally the wrong way?
> Any help would be greatly appreciated?
> Cheers,
> Andy
> Andy Foster
> Royal Greenwich Observatory Tel: 44 (0)1223 374899 (direct)
> Madingley Road Fax: 44 (0)1223 374700
> Cambridge E-mail: [email protected]
> CB3 0HA Home Page: http://www.ast.cam.ac.uk/~ajf
> UK
Hi Andy,
This may work for you. It does not require any new database records.
I am using edd/dm version 2.2.
My calculation record is called counter.
and has the following properties.
CALC: B?(B*(A+1)):0
A: counter.VAL
B: 1
I made a message button to control counter.B.
(titled RESET for both inactive and pressed)
The press message is 0 and the release message is 1.
I hope this helps.
Rozelle
|Rozelle Wright Phone (505) 667-4804 |
|Los Alamos Natl Labs AOT-8 FAX (505) 665-5107 |
|PO Box 1663 MS-H820 Group Office (505) 667-6087|
|Los Alamos, NM 87545 email : [email protected] |
Re: CALC record question Rozelle Wright
<1996>
2025
2026
<1996>
2025
2026
