Matthew(s),
I have just started using version 2.1.3 of 'e2sr' in order to
make use of the macro substitution through a heirarchy of schematics.
However, I seem to have found a bug with the CALC field of calculation records.
If you set the CALC field as: A%6
(which I believe is allowable, as stated in the record reference manual).
The result in the '.sr' file is: A%67 !!
I went through the following to generate this:
sch2edif -n test.sch. (Version 2.2.74)
(Incidently, this gave me a file which had the following:
(property (rename def "def")
(string "test:calc1.B"))))
(instance (rename calc1 "calc1")
(viewRef NETLIST_VIEW
(cellRef ecalcs))
(property (rename CALC "CALC")
(string "A%37%6")))
(net (rename n_22 "n#22")
Where does the extra "%37" come from?)
e2sr test.edf. (Version 2.1.3)
gave:
DESC calculation record
SCAN Passive
PINI NO
PHAS 0
EVNT 0
DISV 1
SDIS 0.000000000000000e+00
DISS NO_ALARM
PRIO LOW
FLNK 0.000000000000000e+00
CALC A%67
INPA test:calc1.VAL .NPP.NMS
The original 'sch' file is:
[schematic2]
uniq 36
[tools]
[detail]
w -1152 722 100 0 n#22 ecalcs.calc1.VAL
-960 400 -896 400 -896 720 -1360 720 -1360 592 -1248 592 ecalcs.calc1.INPA
[cell use]
use eaos -1800 264 100 0 reset1
xform 0 -1696 352
p -2080 -68 100 0 0 def(OUT):test:calc1.B
use ecalcs -1224 120 100 0 calc1
xform 0 -1104 384
p -1341 600 100 0 0 CALC:A%6
[comments]
I also noticed that A%67 generated A%67% ?
Can anyone tell me if they have noticed anything similar?
Am I using the correct flags on the programs? I don't understand what is
going on?
Thanks for any help.
Andy
Andy Foster
Royal Greenwich Observatory Tel: 44 (0)1223 374899 (direct)
Madingley Road Fax: 44 (0)1223 374700
Cambridge E-mail: [email protected]
CB3 0HA Home Page: http://www.ast.cam.ac.uk/~ajf
UK
Re: CALC record question Marty Kraimer
Capfast 3.02.23 and CALC records Andy Foster
<1996>
2025
2026
Visual Basic 4.0 and EZCA Mark S. Engbretson
RE: e2sr and the CALC record Eric Bjorklund, NPSM
<1996>
2025
2026
