> Matthew(s),
> I have just started using version 2.1.3 of 'e2sr' in order to
> make use of the macro substitution through a heirarchy of schematics.
> However, I seem to have found a bug with the CALC field of calculation records.
> If you set the CALC field as: A%6
> (which I believe is allowable, as stated in the record reference manual).
> The result in the '.sr' file is: A%67 !!
> I went through the following to generate this:
> sch2edif -n test.sch. (Version 2.2.74)
> (Incidently, this gave me a file which had the following:
> (property (rename def "def")
> (string "test:calc1.B"))))
> (instance (rename calc1 "calc1")
> (viewRef NETLIST_VIEW
> (cellRef ecalcs))
> (property (rename CALC "CALC")
> (string "A%37%6")))
> (net (rename n_22 "n#22")
> Where does the extra "%37" come from?)
Andy,
I have run into the same problem. edif uses the % as an escape character, so
%37% is an "escaped %" (37 is decimal for the percent character).
The bug is in the file edifRead.c, which doesn't correctly keep track of the
end-of-string after parsing an escape sequence (this results in the A%67 you
observed).
I have been working on this and various other problems with e2sr (mostly having
to do with using busses) and have a fix which I can put into our anonymous ftp
site (once I figure out where it is and how to do it) or mail to you directly,
whichever you prefer.
I have not observed the problems with B=0?1:A or B*(A+1) that you mention, but
I don't use CAPFAST 3.02 either. It might be interesting to see what the .edf
file looks like for these records.
Eric Bjorklund
AOT-6 LANSCE Operations
[email protected]
Capfast 3.02.23 and CALC records Andy Foster
Re: Capfast 3.02.23 and CALC records Nick Rees
<1996>
2025
2026
e2sr and the CALC record Andy Foster
<1996>
2025
2026
