William,
On Fri, 12 Apr 96 13:55:41 HST William Lupton <[email protected]> wrote:
> There is vxWorks global variable device support for ai, ao, longin,
>longout, stringin and stringout records. The vxWorks global variable is
> I propose extending device support to make use of the INP and OUT
>fields and to use an INSTIO string to hold the variable name (36
>characters are available) plus to support a leading "*" character to
>force an extra dereference. If the field is not INSTIO, existing
>behavior will occur, so the change is upwards-compatible.
Good idea - we had an application where the existing name derivation was useless
so in the end we had to design it a different way, but it would have been nicer to
use vxWorks variables with INSTIO and a name unrelated to the record name.
> One could also support trailing "[n]" or "+n" syntax to reference the
>nth element of an array or at a byte offset of n. Is this worth it?
IMHO the "a[n]" array syntax is worth it; "a+n" may be confusing because some
people might think you were providing C pointer arithmetic rather than a byte
offset. What about "a-n", "a[n]+m", "a[n][m]" etc? I'm not suggesting you
implement these, you obviously need to draw a sensible line.
- Andrew
O o ._ Andrew Johnson, Royal Greenwich Observatory
__\\_ Madingley Road, Cambridge, CB3 0EZ
__|ooooo|__ Tel +44 (0)1223 374823 Fax 374700
~~\_________/~~ WWW http://www.ast.cam.ac.uk/~anj/
vxWorks variable device support William Lupton
New EPICS Pages Intalled Jackie Wallis
<1996>
2025
2026
Re: vxWorks variable device support William Lupton
<1996>
2025
2026
