1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: A bad thing happens when I build base/
To: Bill Brown <[email protected]>
Cc: [email protected]
Date: Wed, 1 May 1996 10:16:01 +0100 (GMT)
Bill,
On Tue, 30 Apr 96 11:18:06 PDT Bill Brown <[email protected]> wrote:
> When we do a co of epics from our repository, everything looks fine.  However
> after we do the initial gmake from base/ the sub-directory base/rec/CVS and
> all its contents are GONE!  This makes bad things happen when one tries to
> do a "cvs commit" or "cvs update."
base/rec should not be checked into CVS at all - it is recreated
every time you run gmake inside base/src/ascii.  Your old base/rec
directory is renamed base/rec.bak, and a new directory is created to
hold the newly created *Record.h files.  base/rec isn't the only
directory which is created at compile-time; it should be treated just
like the base/bin and base/lib directories.
Hope this helps,
- Andrew
  O o ._    Andrew Johnson, Royal Greenwich Observatory
     __\\_	Madingley Road, Cambridge, CB3 0EZ
  __|ooooo|__	Tel +44 (0)1223 374823  Fax 374700
~~\_________/~~	WWW http://www.ast.cam.ac.uk/~anj/
Prev: VXI support Ric Claus
Next: HP VXI Modules W. Stephen Syrett
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: A bad thing happens when I build base/ Bill Brown
Next: Re: A bad thing happens when I build base/ Bill Brown
