1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Q] CAMAC Serial Driver.
Cc: [email protected]
Date: Fri, 14 Jun 96 08:47:21 -0400
>    There is a driver for the Kinetic Systems 2917/3922 crate controller.
>This is not a serial driver, but a parallel bus driver with the capability to
>run 8 crates over a distance of about 100 meters.  LANL folks and myself have
>produced a single package which supports the Hytec and the Kinetic Systems, in
>such a way that the device dependent part is pretty cleanly separated.  Adding
>support for another serial driver should be very easy.
The design of the original CEBAF device support would support any CAMAC
interface for which the ESONE/ANSII Standard CAMAC routines were available.
This includes a number of branch highway interfaces as well as the Kinetic
Systems K-bus mentioned above.
We used this at CEBAF for both the serial highway and kbus interface.
It did not include LAM support (added by LANL), but I'm not sure if the
hardware independence is completely preserved -- that is, the ability to
use any existing CAMAC library without modifications.
Chip
Re: [Q] CAMAC Serial Driver. Mark Rivers
Prev: Re: [Q] CAMAC Serial Driver. Mark Rivers
Next: Re: [Q] CAMAC Serial Driver. Mark Rivers
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: [Q] CAMAC Serial Driver. Johnny Tang
