I forgot to add some release notes. I updated WWW.
The additions are as follows:
dbStaticLib
The Following routines are now obsolete.
OLD ROUTINE REPLACEMENT
dbFindRecdes dbFindRecordType
dbFirstRecdes dbFirstRecordType
dbNextRecdes dbNextRecordType
dbGetRecdesName dbGetRecordTypeName
dbGetNRecdes dbGetNRecordTypes
dbFirstFielddes dbFirstField
dbNextFielddes dbNextField
dbGetChoices dbGetMenuChoices
For now the old version will be supported. After one release they
will go away.
Janet forgot to update the base/README file.
The updated version is attached to this mail message
and will be added to bugs for alpha5.
Marty Kraimer
$Id: README,v 1.16 1996/07/16 14:18:48 jba Exp $
3.12 EPICS BASE Notes and Build Instructions.
- By Matthew Needes
Notes:
1. Before you can build or really use EPICS, you must properly set the
environemnt variable HOST_ARCH. The epics/startup/HostArch script file
has been provided to set HOST_ARCH.
2. You must use GNU make (which is now THE supported make utility) for
the build, gnumake. Set your path so that a recent version (e.g.
V3.70) of gnumake is available.
Part 1 - Configuring and Building EPICS Base
1.1 To configure EPICS, edit the following files:
config/CONFIG_SITE - Build choices/HOST_ARCH/Vx location.
config/CONFIG_SITE.* - Location of X, etc.
config/CONFIG - For overriding specific variables.
1.2 To add a target architecture to EPICS:
cd base/config
cp CONFIG.mv167 CONFIG.YOUR_ARCH
edit CONFIG.YOUR_ARCH - For compiler flags / etc.
cp CONFIG.Vx.68k CONFIG.Vx.YOUR_ARCH_CLASS
cp CONFIG_SITE.Vx.68k CONFIG_SITE.Vx.YOUR_ARCH_CLASS
- ONLY IF you are adding a new architecture class,
see note in Appendix A.
edit CONFIG_BASE - Add architecture to list.
1.3 To build EPICS:
cd epics/base
gnumake - To build and install EPICS.
gnumake clean - To clean temporary object files. Top level
clean will remove all the O.ARCH dirs, not
only those specified in BUILD_ARCHS.
gnumake uninstall - Only available at the top level directory.
Cleans directories created by the install.
1.4 "Partial" build commands:
gnumake clean.sun4 - Cleans sun4 binaries in O.sun4 dirs only.
gnumake install.sun4 - Builds sun4 only.
gnumake install.mv167 - Builds mv167 only (a HOST_ARCH build must
be complete before this can be issued).
NOTES:
1. EPICS binaries and shellscripts are installed into the directory
$(INSTALL_LOCATION)/bin/ARCH.
2. EPICS libraries are installed into the $(INSTALL_LOCATION)/lib/ARCH
directory.
3. During a normal build (a "make" or "make install"), the "depends"
dependency will NOT be invoked. Only if "make depends" is run
explicitly, or a "make built_release" is performed will dependencies
be generated automatically.
4. Temporary objects are stored in src/DIR/O.ARCH, This allows objects
for multiple architectures to be maintained at the same time.
While developing source for EPICS, merely cd src/DIR/O.ARCH, and
invoke "make":
cd epics/base/src/db/O.mv167
make dbAccess.o
The above example instructs make to build dbAccess.o for the
mv167 target.
Part 2 --- Configuration Files in epics/base/config
CONFIG - This file is meant to be included in the low-level EPICS Makefiles.
It includes the other EPICS makefiles, and allows individual developers
and the EPICS system manager to override specific variables in the rest of
the configuration.
CONFIG_SITE - This file is meant to be changed only by the EPICS system
manager. It specifies:
HOST_ARCH: The system's host architecture (sun4/hp700/etc).
This now come from an environment variable.
CROSS_COMPILER_HOST_ARCHS: List of unix architectures with cross_compilers.
CROSS_COMPILER_TARGET_ARCHS: List of architectures to build epics for.
VX_DIR: Location of vxWorks.
STATIC_BUILD: Whether or not to build clients statically.
etc.
CONFIG.ARCH - This file defines a particular architecture. It
contains the following variables:
BUILD_TYPE: Unix / Vx
ARCH_CLASS: 68k / sun4 / hp700 / etc.
Architecture dependent build flags. The flag names / contents
depend on your architecture class.
CONFIG_SITE.ARCH - Contains site specific definitions pertaining to a
particular architecture. This file's primary usefulness is to
define site specific compile and link flags.
CONFIG_COMMON - Contains definitions describing the layout of base.
CONFIG_BASE - Defines what subdirectories get built by default under base.
RULES.Vx - Rules for building with VxWorks makefiles.
RULES.Unix - Rules for building with Unix makefiles.
RULES_TOP - Top level rules for building.
RULES_ARCHS
RULES_DIRS - Allows top-level type command syntax in low-level directories.
Table of files to change when building and adding architectures.
etc.
Filename SYS_MGR ADD_VX_ARCH ADD_UNIX_ARCH DEVELOPER
CONFIG m - - m
CONFIG_SITE m m m -
CONFIG_SITE_ENV m - - -
CONFIG.ARCH - c c -
CONFIG_SITE.ARCH - c c -
CONFIG.Vx.ARCH_CLASS - c* - -
RULES.Vx - - - -
RULES.Unix - - - -
CONFIG_BASE - - - -
CONFIG_COMMON - - - -
CONFIG_ENV - - - -
RULES_ARCHS - - - -
RULES_DIRS - - - -
RULES_TOP - - - -
m - Modify an existing file.
c - Create a new file.
* - Create an ARCH_CLASS file only if you are adding a
fundamentally new architecture, such as hp700 or
a SPARC VME board. If your board is 68k based,
you will not need to create CONFIG.Vx.68k,
since it already exists !
Part 3 --- Configuration File Inclusion Tree Examples
---------------------------- hkv2f example --------------------------------
(files are numbered in the order of their inclusion)
src/db/Makefile.Vx (An example EPICS makefile)
| +--- 3. RULES.Vx
| Default rules.
+------- 2. CONFIG
| | | +- 1. CONFIG_SITE
| | | HOST_ARCH = sun4
| | | BUILD_ARCHS = $(HOST_ARCH) mv167 hkv2f
| | | VX_DIR = /vxworks
| | | More.
| | +--- 2. CONFIG_COMMON
| | General info about base.
| +----- 3. CONFIG.hkv2f
| ^ BUILD_TYPE = Vx
| | ARCH_CLASS = 68k
| | Arch Specific Compiler Flag Setup
| +--- a. CONFIG.Vx.68k
| Compiler/utility setup for ARCH_CLASS
+------- 4. CONFIG_SITE.hkv2f
Site Specific setup
---------------------------- sun4 example --------------------------------
src/db/Makefile.Unix (An example EPICS makefile)
| +--- 3. RULES.Unix
| Default rules.
+------- 2. CONFIG
| | | +- 1. CONFIG_SITE
| | | HOST_ARCH = sun4
| | | VX_DIR = /vxworks
| | | More.
| +----- 3. CONFIG.sun4
| BUILD_TYPE = Unix
| ARCH_CLASS = sun4
+------- 4. CONFIG_SITE.sun4
Directory locations
Part 4 --- EPICS makefile rules
Rules supported by lower level Makefiles:
depends - Generate include dependencies
build - Builds objects, using libraries from "build_libs"
install - Installs executables in bin/ARCH
clean - Cleans objects
[no subject] Michael Bordua
Stringin Record Jens Bergl
<1996>
2025
2026
<1996>
2025
2026
