1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: "Edge sensitive" record processsing.
To: [email protected], [email protected]
Date: Fri, 16 Aug 1996 09:43:47 -0500
Take a look at the wait record (misnomer - should be called the "whiz bang zoom
record").
>From the Record Reference manual:
Output Link Execution Options
The outputs of the wait record are not necessarily executed every time the
record processes. This allows "downstream"
processing of records to be done conditionally. The "output execution" options
are decsribed below.
      Every Time: Outputs are executed every time the record processes.
      On Change: Outputs are executed if the result of the calculation (VAL) is
       different than the previous time the
      record was processed.
      When Zero: Outputs are executed if the result of the calculation is zero.
      When Non-zero: Outputs are executed if the result of the calculation is
       not zero.
      Transition To Zero: Outputs are executed if the result of the calculation
       is zero and the previous value was not zero.
      Transition To Non-zero: Outputs are executed if the result of the
       calculation is not zero and the previous value was zero.
Hope this helps.
<josH>
Prev: Re: "Edge sensitive" record processsing. Ned Arnold
Next: Re: "Edge sensitive" record processsing. John R. Winans
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
