1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: "Edge sensitive" record processsing.
To: [email protected]
Cc: [email protected]
Date: Fri, 16 Aug 1996 09:42:59 -0500
> I've got a situation where I need to cause a PV to process when a second
> PV makes a transition in one direction.  In otherwords, I need to fire
> PV1 when PV2 changes state 1->0, but not on the 0->1 change.  If it matters,
> PV1 is a BO to a GPIB device.  A particularly ugly GPIB device, at that.
> I'm sure I've seen this done (short of writing a state machine in SNL),
> but it escapes me.  Probably just another case of "Berkeley Brain Rot."
> Anyhow, suggestions, comments, flames, etc. appreciated.
> Disclaimer:  Any opinions are my own and have	    |  -bill
>     nothing to do with the official policy or the   |   [email protected]
>     management of L.B.L, who probably couldn't      |   Berkeley, CA
>     care less about employees who play with trains. |   aka [email protected]
I can think of two ways ...
  Use a CALC record and utilize the LA, LB, LC, ... fields that tell you
  the previous value of an input. An edge could be detected as (A&!B) where
  A points to PV1 and B points to the CALC_RECORD.LA .
  OR, you could use a WAIT record which is much like a CALC record but has
  "conditional" processing of an output link. One of the conditions is when
  the result of the calculation changes from 1->0. BE CAREFUL ! The input
  links on a WAIT record are NOT PV LINKS (until 3.13, that is). They are
  raw text strings that indicate the PV name, which can change during
  run time.
  Have fun ...
  	Ned
Prev: "Edge sensitive" record processsing. Bill Brown
Next: Re: "Edge sensitive" record processsing. S. Joshua Stein
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
