This mail is made of the recycled electrons
Mailer: Elm [revision: 70.85]
Gabor wrote:
> I'm working on dbStaticLib.c modification and this is
> now working on PC (!) (R3.13.alphaX) and R3.12.2.D but only
> on processors which has FP. I have discussed with Matthias,
> and he told me, that the hack we have on LC board startup scripts:
> # hack gnu fp-soft library error
> ___fixunssfsi = 0x800000
> is not enought - he has red something from you. Could you help me ?
> Regards,
> Gabor
To compile EPICS or vxWorks applications to be run on 68LC040 or
68EC040 (mv162 without hardware floating support), -msoft-float
flag must be used with cc68k cross compiler and that flag must
come AFTER "-m68040" on the cc68k command line.
If you are using 5.1.1 or earlier version of vxWorks mv162lc BSP,
you do need fix libMC68040gnuvx.a library. The hack gnu fp-soft
library with " ___fixunssfsi = 0x800000 " is only hoping that
there will be no actually calls to ___fixunssfsi in your
vxWorks applications or EPICS in your case.
I recommend you to use vxWorks 5.2 or 5.3 vxWorks. If for some reasons
you really want to use 5.1.1 and try to fix gnu soft-fp library,
you may use the following procedure as a reference:
Delete the following modules in libMC68040gnuvx.a :
gccUss040Alib pow fmod support log__L exp__E
Extract the following modules in libMC68020gnuvx.a and add
them into libMC68040gnuvx.a:
floatLib shell shellLib gccMathLib mathSoftALib
gccUssALib uss_dpfncs uss_dpopns uss_fpfncs uss_fpopns
uss_xlfncs modf frexp ldexp
ar68k -d libMC68040gnuvx.a <del-module>
ar68k -x libMC68020gnuvx.a <extract-module>
ar68k -r libMC68040gnuvx.a <add-module>
Hope it helps,
Johnny Tang
Johnny Tang Voice: (804)249-7239 E-Mail: [email protected]
Jefferson Lab
Continuous Electron Beam Accelerator Facility
12000 Jefferson Avenue, MS 85A
Newport News, Virginia 23606
Re: rec/devSup advise needed Marty Kraimer
Re: rec/devSup advise needed John R. Winans
<1996>
2025
2026
R3.13 App Devl Guide Janet B. Anderson
Seeing forward links from SNL? swampler
<1996>
2025
2026
