>Andrew Johnson wrote:
>> IMHO the new formats should not be hard-coded anywhere other than the
>> drivers/device support which use them; the "link_type" in the database
>> "device" definition should be something else which is definable in an
>> ascii file (and convertable into a VME_IO.h file for example, which can be
>> #included by the device/driver). This way anyone could add a new address
>> type without needing to rebuild base, but you should still be able to
>> retain backwards compatibility for existing device/driver support.
>I just read this more carefully. I think I now see what you are saying.
>Just like 3.13 has ascii definitions for menus and record types
>let it have an ascii definition for a link type.
Add support for these things to GDCT and you will be caught back up to the
hardware-config subsystem of RX ;-)
--John Winans
Re: mv162LC problem with floating point libraries in 5.1.1 Johnny Tang
Re: rec/devSup advise needed Ric Claus
<1996>
2025
2026
Re: rec/devSup advise needed Tim Mooney
tclCa package (was et_wish) Claude Saunders
<1996>
2025
2026
