1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: A24 DMA into the hk nitro 60
To: [email protected]
Date: Thu, 05 Sep 1996 16:55:53 -0600
Dear all,
I made the attached additions to the Heurikon Nitro60
vxWorks BSP in order to get DVX 2502 A24 DMAs working. Most
of this code isnt Heurikon specific (excepting tests which verify
that the A24 available pool is within 2MB of sysMemTop()).
The API here follows the model developed by John Winans of APS
for the mv167.
All comments appreciated.
Jeff
 * hk nitro 60 specific A24 memory management routines - joh 9-4-96
 * A user may call sysA24MapRam() to allocate a block of system ram
 * available to VME A24 of the specified size which is non-cacheable.
 * If space is available, then a memory pool is created for future use
 * by device drivers via devLibA24Malloc() and devLibA24Free().
 * sysA24MapRam() should be called early during the system boot in
 * order to guarantee that the allocation will occur in the upper two
 * megs of system ram since:
 * 1) this is all that can be seen by VME A24  within the hk nitro 60.
 * 2) wrs free memory allocation occurs from the top of pool down.
 * A warning message is printed if a suitable block of memory cannot
 * be allocated.
static PART_ID          a24DmaPartId = NULL;
  * hk nitro sysA24MapRam()
  * joh 9-4-96
STATUS sysA24MapRam(unsigned long size)
        void    *pBufDMA;
         * only one init allowed
        if (a24DmaPartId != NULL){
                fprintf(stderr,
"sysA24MapRam: attempt to initialize twice was ignored\n");
                return(ERROR);
         * verify that we can get a non-cacheable region
        if (!CACHE_DMA_IS_WRITE_COHERENT() ||
                !CACHE_DMA_IS_READ_COHERENT()) {
                fprintf(stderr,
"sysA24MapRam: Warning - unable to create non-cacheable region\n");
                return ERROR;
         * clip to 2MB boundary
        if (size >= 0x200000)
        { /* Maximum size is 2MB clip it */
                fprintf(stderr,
"sysA24MapRam: Warning - hk nitro A24 pool clipped to 2MB\n");
                size  = 0x200000;
         * Allocate the non-cacheable region
        pBufDMA = cacheDmaMalloc( (size_t) size);
        if (pBufDMA==NULL) {
                fprintf(stderr,
"sysA24MapRam: Warning - unable to allocate non-cacheable region\n");
                return ERROR;
         * Memory must be in the upper 2 Megs inorder to be available
         * on VME A24
        if (pBufDMA < (void *) (sysMemTop() - 0x200000) ) {
                fprintf(stderr,
"sysA24MapRam: Warning - unable to allocate within A24 accessable window\n");
                cacheDmaFree(pBufDMA);
                return ERROR;
#ifdef EPICS_DEBUG
        printf("sysA24MapRam: buf =%8.8lX size = %8.8lX\n");
#endif
         * Build A24 memory pool
        a24DmaPartId = memPartCreate(pBufDMA, size);
        if (a24DmaPartId == NULL)
                return ERROR;
        return(OK);
 * hk nitro sysA24Malloc()
 * joh 9-4-96
void *sysA24Malloc(unsigned long size)
                return(NULL);
        return memPartAlloc(a24DmaPartId, (size_t) size);
 * hk nitro sysA24Free()
 * joh 9-4-96
STATUS sysA24Free(void *pBlock)
                return(ERROR);
        return memPartFree(a24DmaPartId, pBlock);
______________________________________________________________________
Jeffrey O. Hill			Internet	[email protected]
LANL MS H820			Voice		505 665 1831
Los Alamos, NM 87545 USA 	FAX		505 665 5107
Prev: PC GPIB performance watson
Next: R3.13.0.beta2 now available Marty Kraimer
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: A24 DMA into the hk nitro 60 Nick Rees
