CAI MINGFU wrote:
> 1. crash with rsrv_init(), which is invoked by iocInit()
> file: ./src/rsrv/rsrv_init.c
> crash with vxworks function: errnoOfTaskGet(taskId) if taskId = -1
> the errnoOfTaskGet() calls _taskTcb() and if taskId is wrong
> it will cause Page Fault.
> wrong:
> #define DELETE_TASK(TID)\
> if(errnoOfTaskGet(TID)!=ERROR)taskDelete(TID);
> corrected:
> if(TID >= 0 && errnoOfTaskGet(TID)!=ERROR)taskDelete(TID);
> Remark: DELETE_TASK should check TID, if not -1 then go on.
This was written before the call "taskIdVerify()" was added to the
vxWorks API. Here is our corrected version:
if(taskIdVerify(TID)==OK)taskDelete(TID);
The other PC port change to base/src/rsrv was incorporated
as suggested.
I have not incorporated your changes into base/src/db/dbScan.c
(I suspect that Marty will take care of this).
Jeff
______________________________________________________________________
Jeffrey O. Hill Internet [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos, NM 87545 USA FAX 505 665 5107
- Re: incompatible problem of EPICS with vxworks 5.3 Peregrine McGehee
- Re: incompatible problem of EPICS with vxworks 5.3 Marty Kraimer
- incompatible problem of EPICS with vxworks 5.3 CAI MINGFU
logistic matter for EPICS meeting @ CERN / attendees Matthias Clausen DESY -MKV2/KRYK-
<1996>
2025
2026
<1996>
2025
2026
